Glaze
Its not your hand break. Have you enough/ to much auto fluid. Have you removed the battery. Have you removed the pcm fuse. What you have posted is about a number of issue. Fresh auto fluid and new filter can change the response in change. Even auto fluid of different brands does this. How long between auto and engine oil change will change the efficiency of both. Engine at 5k, Auto at 5-7k diff also. I guarantee you if something isnt already worn or clogged you car will function more efficiently.
Just checked trans fluid in park idle the level is way above the crosshatch ffs can I pump it out from the dip stick filler or I gotta remove the pan again and let some drain out..? I’ve always used Castrol dexron 3 changed at 170xxx then at 190xxx for a decent clean around. Always changed engine oil every 5k. Haven’t done diff yet need to do it soon.
Took negative lead off battery for a reset. Also I got my brother to sit in the car and change through gears as I was watching the block - resulted in the block shaking pretty rough on the driver side from park to reverse or any gear from or to drive, could this be engine mount problem which could also cause a shaky idle? Cheers
