Milesvtcalais
- Jan 5, 2020
- 51
- 6
- 8
- Age
- 23
- Location
- Gold coast
- Vt calais
Hey mate, thanks for your replies. I can almost guarantee the motor hasn't been decked or the heads have been shaved as it's a stock 3.8 from a vt calais with only 190.000ks on it. What I'm confused about is the car runs smooth like dead smooth, you cant even feel it running but it just doesn't want to rev or go anywhere, I wouldn't even ride out a burnout in the wet. I've gotten a manual for installation from mace engineering and it never specifies preload it just has a torque reading. The other day when I started the car it was running terribly, shaking misfiring all that kinda stuff but as it warmed up it fixed itself and ran smooth as. Then it started to tick so I took it for a spin and when I came back 15 mins later the tick went away. As mentioned the car felt extremely underpowered and it just didn't want to rev but it still idles well. Confusion. I spoke to a bloke about installing them but he wants $300 just to set the pre load which is completely out of the picture as this is a project car for me, a 16 year old on his L's with no job anymore thanks to covid 19.Issue is without measuring preload we are only assuming the heads haven't been shaved or the block decked or an aftermarket cam not fitted and that everything is within spec. Do the former i mentioned above and go from there. He could have a stuck lifter as is reasonably common but until preload is checked we are simply guessing. Mine developed a rattle afterwards but I had to go through the entire process over to figure out where to. It took me days to figure out the issue and then four weeks at the garage fixing the problem, two days work that took weeks before I got the ute back.
