Muz-VT
- Sep 2, 2005
- 18
- 1
- 0
- '99 VT SS Supercharged
Well, new air filter & cleaning TB *May* have made a diff .. was still warm when i left to go on a drive this evening, and yet ran rather well, coming home was perfect.. Will try the MAF cleaning next .. noticed when i had the intake arm off today that there was small bugs & leaves on the mesh on the filter! God only knows how that had gotten past the air filter! Cleaned the mesh with a rag, but didnt touch the actual filter .. would a normal "degreaser" spray (ie, superchaps deagreaser in a can) work the same as the crc stuff? Seems to be good at what it does .. used it on the TB, eats up the grime, and leaves a VERY nice clean TB atfer its done
DO NOT use degreaser & DO NOT touch the insides of the MAF.
Only use “CRC Contact Cleaner”.
Electrical / Electronics guys use this stuff to clean contactors and sensitive electronic equipment. The spray comes out very cold does its cleaning and then evaporates quickly leaving a super clean surface.
You can buy the cleaner from electrical wholesalers, around $10 to $15.
Also follow instructions on the can as I think you can “burn” your skin as the spray comes out very cold.
Muz
