Sounds like what I want, going to order one and see - the Monaro threw up the "check engine" light and I want to know what it is because sitting in the drivers seat not a damn thing has changed just the bleeping light.
I'll be using a laptop so I'll report back when I get it - just a suggestion TazzI - have you thought of showing your diags running and it showing a code or historical codes or something, the YouTube demo shows a car that has no faults so I don't really get an idea of what is going on from the video.
*edit*
actually looks like you are out of stock according to the website - please let us all know when you have more.
Ah right, if you are receiving an engine light, then you will have at least 1 history fault and possibly a current fault if the engine light is on at the time of reading. Either way you can see the fault logged into he ECU. Reeeeealy common issues to occur though are oil pressure sensor failure and ABS module failure.
In VT-VY, ABS module failure causes an ABS warning on dash though along with an engine fault, although no fault is actually logged into the ECU because the ABS module is preventing communication on the ALDL line which then causes the cluster to not "see" the ECU or any other module causing heaps of faults to display on the dash... kinda like if you power a cluster up outside of a car.
Ah yes, I do completely agree, but the latest video you see there was my own VE SS which has no faults. The purpose of it was to display the live engine/transmission data viewing. The only way to display the fault reading is to power the ECU up on bench (I did in an old video) to make faults appear and demonstrate that section, although I cannot then display the live data viewing easily since theres no inputs into the ECU.
The next video I make, I think I will have to take two recordings, one in car and one o the bench to cover both sections. :beer chug:
Oh, and have just updated stock, the site ran out last night but theres still plenty here.
