VX Commodore Engine light on highway
SLIfox
2001 VX S2 Calais
Hey everyone,
I recently bought a 2002 VXII Commodore. When I went out this morning, I went to overtake someone on the highway then the check engine light came on and the car went into limp mode and I pulled over.
Turned the car off and it went away. (No problems after that)
I drove the car 200kms after buying it on the highway and didn't have a single problem with it.
Does anyone know what could have caused this?
Car is a V6 btw.
Thanks
commodore665
expat Saffa
54
New Zealand via Cape Town
2005 SV6 & Alfa Romeo 156 V6
I’d take it to your mechanic and get it scanned for codes , that may pin point what happened
SLIfox
2001 VX S2 Calais
I did ask if it was possible to pull a code. Their response was since the light is gone it is unlikely they can get a code.
Is this true?
commodore665
expat Saffa
54
I would have thought the ECM would have stored the code
ant797
bunbury
vy s
They proberly couldn't be fucked ...there is a write up on here if you do a search on how to bridge the pins on the scanning port to get codes ...
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
The codes stay in the history for a certain amount of time.
SLIfox
2001 VX S2 Calais
Thanks everyone,
Did spark plugs, a throttle body clean (it was caked up) and air filter.
I will give it a go on the highway. If it trips the Engine light again I'll see if someone can get me that code.
She's a fantastic little car and want to fix it asap.
Thanks again to everyone who replied.
50
Blackwater Queensland
L67 vx commofore
you wont get any codes at all trust me my vx used to do just this fine driving around town but on the highway soon as you hit 100khr check engine would come on pull over shut it off restart drive off no check engine light again until you hit 100 had it in every mechanic shop n tech 2 place around no one could explain why as soon as it hit 100 check engine would come on n then vanish after a restart until you hit 100 again( i gave up after a month n engine swapped it with my L67......... just recently im hveing issues with check engine light again........id b going over your loom looking for busted or rubbing wires seeing i dont hve the patientce i simply brought a new loom to try n fix mine if it continues next stop is ecu n bcm)
ant797
bunbury
vy s
Could be a det sensor I would amagine the engine might go into limp mode if the car was detonating or the the sensor was playing up ....also if it has sensor on the catolyc converter and to much fuel is igniting in there
ant797
bunbury
vy s
And don't trust him look for codes I took some advice from ppl of this forum without looking for codes saying it's most likely this or that usually this replaced those things without checking codes ddnt solve the problem checked for codes was something completely different replaced that part even though someone on here told me I needed to do something even more involved to fix it and wellah code went away with a 20 bucks part an hour's labour other guy sujested would of needed a trans soecialist
