VX V6 not cranking over?
HoldenHoon
33
Australia
VS Berlina V8
Hi everyone. I have just installed complete ecotec running gear into a VX. These parts were from the wreckers so the bcm ecu and such don’t match. The BCM is the original one in the car so the key is already linked to it allowing me to unlock and lock doors etc. The ecu is from another car. My problem is that the car won’t crank over at all. Shouldn’t it atleast crank over 1-4 times if immobiliser was active? The fuel pump turns on and I’ve manually turned over the motor from the starter and I’ve got spark. It just won’t turn over from the key. Also, the bcm had been linked to an ls computer before hand. Any differences between the ls and eco bcm?
lout
60
Langwarrin Victoria
you need to link the computers
HoldenHoon
33
Australia
VS Berlina V8
Yeah I’m going to let holden do that I’ve tried using a snap on scanner and it wouldn’t let me link them without the BCM security code. I just find it weird why it won’t crank at all. I put a different ecu in my VY V6 and it cranked 2 times then stopped. This car won’t crank at all.
BlackVXGTS
Melbourne, SE
What's the condition of your battery like? What's the present voltage?
