ReaperManVY
- Jun 20, 2019
- 11
- 1
- 3
- Age
- 42
- Location
- Tasmania
- VK Commodore Wagon With 5 speed W58 and Triple SUs
Hi fellas,
Really in need of some advice here. We're recently purchased a VY II V6 Sedan and had a rather bad leak from the Front Oil Seal from the crank. After a ridiculous amount of effort with a 'Y' shaped balancer removal tool I'd finally got the thing off, replaced the seal and bolted the balancer back. Also had to make a basic tool which was essentially a steel bar with a couple of lugs to hold the balancer in place while I torqued the balancer bolt back up.
While I was trying to remove the balancer, it had actually snapped one of the bolts, so had to put a tack of weld the bolt to the balancer itself.
Upon starting the damn thing up, it's running rough as guts, and is pinging its head off while driving, and at a stand still it's pinging under throttle...
First of all (As I've got little understanding with CAS), is it likely the tack weld with the bolt affected the sensor somehow??
Also, the battery was removed on both terminals before welding just out of safety..
Any ideas on what is going on here guys and how to get it sorted?
