I know exactly where the single uni is. If you must know the place I spoke to is Dynamic Balancing. They know a lot more than you ever will and have replaced heaps of unis on these types of tailshafts, because of people doing it the wrong way doing exactly what you do. So go ahead tell people how to damage their uni. I tell people how not too. At the end of the day it's not my money so if people listen to you and damage the uni and end up having to get a new one fitted then so be it. As for me I do things the right way.
Ahh Slosh you got to be a likeable oldie like a box of chocolates.
Most workshops/mechanics do the cb tailshaft replacement the way its been engineered that way to come apart for c/b repair without damaging any unis, and then sent out to spin up if wanting to get check the factory spec for harmonics at certain rpm.
Every heard of proper brass drift/soft jaws?? It”s not a cold chisel or an angle grinder blade which should not be used on bearings especially rear hub bearings so not to cut spline and damage hub.
Sounds like you have been there done that yeah man, ouch costly mistake.
That”s right you always do the right cheap thing living in a glass house.
Yes I do recall Dynamic Balancing, didn”t you pay $680 to replace just the simple VE c/b and donuts which didn”t fix your bad vibration issue which they couldn”t diagnose in the first place to be a rear hub bearing not just a cracked rubber in the tailshaft centre bearing. Hope you got expensive discount vouchers for mentioning them online
That's the next step. I will start with the one that was loose a while ago. I'm not really wanting to touch it myself is all. Feeling quite deflated about the whole thing. It was $688 spent today and it didn't fix the problem. Until today I haven't driven the ute since Saturady as I was concerned about major failure.
Now I don't really want to drive it until it's to get it to a place of repair. Don't know where to take it? Too many qualified people are making mistakes. Starting to feel like I'm back to when I had no one I could trust to work on my vehicles at fear of them not doing it right or giving me the run around. This hub bearing should have been replaced that week, not told to see how it goes after tightening the nut and not worry about it..... Need to be able to trust trained people to give you the right advice not make errors that cost me money.
Interesting comments you made ^^^^ in your Brian/Taylor post. Yep you do things the right way and then criticise people and blame professionals who do. Sounds like Scrooge McSlosh telling porkies again
