Update -
Centre Bearing arrived today,
Purchased on the 14 September, Delivered today 25 October,
I spent the Afternoon installing the unit,
The one thing I did notice, the tail shaft had already been marked,
So you would assume it's been replaced before.
Well I know it was replaced before, because "the Torx Bolts in the Centre CV joint were only hand tight",
I kid you not !!!
I undid the bolts with my fingers.
So you can guess my Reaction/Comments.
So when I got the Tail Shaft out,
It looked like a Bush Mechanic had relaced the existing centre bearing,
The Front Sling Ring was bent, the rear Sling Ring was also a bit out of shape,
And I then checked the bolts holes and flanges for damage,
But that was ok.
After getting the old bearing off the shaft, and everything cleaned up,
I had to panel beat the both Slinger Rings [Front and Rear], and straighten them out,
And ended up not to bad in the end, well better than they were.
When every thing was dry,
Tapped the -
Front slinger ring on,
Then the Centre Bearing, [with a thin film of grease on the shaft and Bearing],
Then lightly tapped it home,
Then Rear Slinger Ring,
Then the CV Joint, [I had to open the seal clamp, so the rubber boot would slide on ok without splitting it]
Then re-fitted the seal clamp,
Then the CV Shaft Circlip,
I packed some extra grease in the CV joint, as It looked a bit lite on,
It was just like a Jigsaw, and every piece fell into place.
Cleaned up and went for a Road Test
The Road test took almost an hour, 60km/h, 80 km/h & 100 km/h
Very please with the result, and drove fantastic,
So Its ready to get the Roadworthy, and to Transfer it to me,
Possibly a couple of small road trips. [Test Drives]
Then its ready for the Weekend krusing [No Pun Intended]
to Mansfield and High Country
eg: Craigs Hut, where they Filmed "The Man From Snowy River", and other scenic sights]
I was reluctant to do this project, but I guess I had do so something during lock down, and keep the grey matter active,
Next will be Servicing the Transmission,
and changing the oil in the Front Diff, Transfer Case and Rear Diff,
Edit:
Film Clip Added of the Old Centre Bearing,
Images Added of the New Centre Bearing.
