You can't believe it chaps, I only drove around for a couple of days and the gauge started misbehaving again. Inaccurate readings, all over the place. This time I could not hear the pump. The engine started to starve for fuel.
I took a few pictures. The blockage is certainly the problem, cause as soon as you clear it you are back in action all round.
I reckon a new pump in a new tank would be good and fine. The tank and filter would dirty at the same rate, and not upset things.
But you put a new pump in an old tank, or get some crap in your new tank, the suction pulls it straight to the pump mouth and blocks it. Like so:
That stuff is blocking the pump mouth. You can see it is only sucking fuel shy of the fold.
A lot of it is kind of fluff. I wonder whether some of it came off the new filter? I have that Icon pump off Ebay.
Just in case, I put another filter back on I had cleaned up off one of the other senders I scavenged. It is not fibrous at all, although really they seem identical.
That sure as heck fixed the issue for now, anyway.
Noticed the new and original tanks are different. I don't know if it is anything to with it.
New is like this. I went with new again cause it certainly looks better with this extra screen around it.
My original pumps have a tank that lacks that screen. Maybe they came like that, or maybe someone has pulled them off in the past, although I can't imagine it. If it happens again I am going back to the old tanks.
Finally, I noticed that it is easy to twist the electric plug at the top, so it might be wise to make sure that is straight when you reassemble.
Twisted, as I found it when I pulled it off this time:
Now straight. Couldn't hurt to make it right.
Needless to say, I extra tubbed out the tank this time, and I carefully filtered the fuel I siphoned before I added it back in. Although I tried to be clean previously. I just mean obviously a bit of extra care here saves some grief. Clearly, you don't want dirt in your fuel tank, cause the old VZ is pretty fussy.
Gave it a new coat of paint too, in the hopes it might treat me better. Police certainly are.
