Silverbird
(Blake)
- Oct 4, 2013
- 353
- 32
- 28
- Age
- 54
- Location
- Brisbane
- VZ Executive Station Wagon
Hi and welcome, Shelly.
If you have the rough idle problem. you'll want to work through systematically. First get it checked for trouble codes. If there's nothing, then check your vacuum hoses for cracks etc. If they are okay, check fuel filter is not blocked (replace it if it's old) and then see if it's any better. If no better, get some throttle body cleaner and clean the throttle body. Check and see if any improvement. If still running bad, replace the plugs (if they are due). Again check how it's running. If still rough, replace the coils - I did all 6 and the manifold gasket at the same time.
Best of luck
Best of luck
