dooboolacky
- Jan 31, 2021
- 8
- 2
- 3
- Age
- 57
- Location
- Perth
- VZ LE0 Captiva april 2006
So I had an oil flow issue owing to oil sludge in the sump that led to engine knocking and I think a partially shredded bearing. I am hoping to just replace the bearing, with the engine jacked up, but still in the car. At the moment I have got most of the side bolts for all 4 crank bearings off and was about to start pulling out the bearing support plates. But the plate holding the rearmost bearing is a bit puzzling.
The two outermost bolts of the four holding the plate on in the photo are right along side the holes for two of the sump bolts in the block casing. So I can't get a socket on the bolt and I can't get a ring spanner on them either. And they are recessed and tight enough that I would probably wear the corners off them with an open ended spanner. I tried both 1/2" and 3/8" 13mm sockets without joy.
Is there some special tool or socket I need to get at those?
Thanks.
Thanks.
