ssute57l
- Feb 11, 2006
- 223
- 3
- 0
- Age
- 48
- VYII SS UTE
Don't run the cables inside the car as these high current cables have no fuse protection, running them along the inside is a very big fire hazard in the event of a short ar acco (interior and carpet will burn fast and toxic).
Run them under the car in a tubing on the opposite side of the fuel and brake lines and not cable tied to these lines,
You can run them on the higher side of the chassis and they wont get pinched by speed humps etc (this is also shorter and reduces voltage drop).
Earth to chassis/ chassis to block is ok provided they are clean and secure and of good size, slight corrosion may make starting hard so use a preventative on it for best results
