And yet you completely ignore the bit about the cooling system been pressurised. Water under pressure does NOT boil at 100° C this is scientific fact. I've posted links and charts with the relevant info. Pressuring the cooling system raises the boiling point of the coolant much more than running a 50:50 mix of water and glycol. You can keep posting the same dribble but you are factually incorrect and completely ignoring a major component/function of a pressurised cooling system. You also completely ignore the fact that the V6 ecotec/L67 normal operating temp is from 91°C to 104°C (thermostat temp to low speed thermofan on temp).
The OP's problem is that the engine is loosing coolant and it's 99% likely that the intake gaskets are fucked. When this occurs the engine will slowly loose coolant via the combustion process. If the gaskets get bad enough than the cooling system will not pressurise correctly and an overheating condition may then occur. In this case the failure has no direct link to the type of coolant used but rather a loss of coolant and lack of pressure in the system.
I have no disputes regarding a possible cooling system failure as l mentioned to "ORTHAS".
Adding water has not fixed it, it has reduced the possible boiling temp characteristics of what mix was provided buy the repairer. The repairer did not add plain water for a reason.
So why highlight your possessive need to question me, thats if this is in fact a genuine thread and not a concocted baited forum convisation for your pleasure.
Unless you Immortality physicaly diagnose an engine in person or by remote correspondence including dismantling the engine you are just speculating.
Providing whatever you have stated in hole, its realy not a firm diagnosis at this stage, your chemistry resurch piontless.
Some of your dribble is about bagging the charactoristics of additives recomended by vehicle manufacturers that you disagree are nessesary, or whatever else drives you disliking.
As l support following the manufacturers guides and not you, is it possible you feel enraged by my choice, and you choose to harass in your sly ways.
Could that explain your posessive need to address my general advise/oppinion as a forum member to "ORTHAS" thread rather than provided your advise to him direct.
If the factory cooling system is functional, the recommended additive will assist the engine within the set manufacturing specs.
"ORTHS" stated he/she couldnt find a thread with his problems.
Yet you say you have covered all this before. Rather than create a science debate for your enjoyment as you stated, at this stage it has no grounds to support what seems to be "OTRTAS" issue.
My suggested application of a coolant mix has been pinpointed buy you as factualy unessesary/incorrect.
You seem to be gratifying yourself with a empty diagnoses.
Grow up!
