I have an auto VX exec LS1 backed with an auto. the paint on roof and bonnet faded, 168,000km on the clock, due for suspension freshen up. pain freshen up and the steel wheel well they have to go. i recon of i upgrade the suspension with something low, fresh paint, maybe a set of CV8Z wheels or something it will be a nice car once again especially if i squeeze out some more power from a dyno tune. it will cost a lot less then upgrading the car to something else plus to try sell it in its current state would loose to much. but a manual conversion would make all the difference.
so lets start a parts list
T56
clutch
flywheel
tail shaft???
pedal box
ecu sorted out converting it to manual from auto. (can this happen at same time as maybe a dyno tune or is the software in ecu completely wrong?
then there is wiring... is it easier to replace entire auto loom with manual one? or is it as easy as bridging the neutral starter switch etc.
to sell this car id get maybe 5000 bucks, to get into something manual, maybe a manual VZ SS id have to spend at least 10grand... the said VZ could have its own list of gremlins what wond be found till in ownership. if i spend similar coin on the VX it would have new suspension plus a real freshen up essentially lasting me alot longer. the look of the VX is realy nice also .... what ya recon...
