Wh statesman tailshaft issues
Menz1979
45
Kyabram
2000 LS1 6 speed manual statesman
G'day all I've got a mild LS1 Wh statesman that keeps ripping the three mounts at the rear of tailshaft were it bolts to the diff when U give it a lot. Is there anything l can do to sort this issue. Cheers
_R_J_K_
Zenki S14
Got pics of the damage?
Lex
Geelong Victoria
VT Executive S1 V6 6 speed Auto Wagon
You using new rubber dough nuts & new bolts & nuts with the proper strength, hardness (dont know the proper engineering term)?
H
harrop.senator
Guest
Correct tensile is the term brother.
H
harrop.senator
Guest
Thanks harrop senator, much appreciated. Now will l remember the name in the future? 2 minutes less? hahaha :) Well maybe 3 minutes.:)
Don't worry I probably look incompetent at my job with how many blanks I get and have to sigh and be like you know what I mean, the wingo haha.
If brain farts left marks I'd be changing my hat's more than my jocks. We all get them.
  • Haha
Reactions: Lex
Jezza
Now with LS1 power
South Australia
WH Statesman International
Are you getting vibrations in the car as your driving and it gets worse the more worn it gets?
If you are check to see if its been mounted around like this photo
If it looks like that then you've got it mounted the wrong way around. The blue markings are the 'fat' part of the coupling and you will want to swap the side each are mounted as shown in red. The tailshaft rotates clockwise if your looking towards the diff or anticlockwise in this photo(looking to the front of the car). So you want to make sure that the tailshaft is pushing the fat part of the coupling towards the diff which would be opposite to this photo.
Hopefully this makes sense if this is the issue your having. For me this all happened because i bought couplings from a brand called Cozza and found they've got them labeled incorrectly which caused my issues.
As an example of correct fitment this is the trans bolting to the tailshaft with a correct Holden coupling
You can see the from this angle going anticlockwise the trans pushes the fat part towards the tailshaft and doesnt pull it.
