J_D 2.0
- Mar 20, 2020
- 2,965
- 6,996
- 113
- Location
- Ipswich
- 2009 VE SSV M6 on LPG and 2022 Kawasaki Z650L
Its a 5 speed 5L40E because my 08 SV6 is (mines the same colour as well). Bitch of a thing to replace as they were only in the upper spec VZ and upper spec early VE models so rare as rocking horse shite to find.If it's the 5 speed auto needs a 5l40e , expensive replacement. I think series 2 has the 6l50e 6 speed . Cheaper replacement and more reliable. Need to figure out how many gears your transmission is.
I had transmission issues with mine and got quoted $5500 to rebuild the transmission I had. No swapsies as there aren’t enough of them around. I came to the conclusion that it would be cheaper to convert it to a 6 speed but it’s in no way easy as the coms protocol is different between the two so the ECU needs to be fooled into thinking the new 6 speed is ok to run with.
I ended up changing the solenoid valves and changing the fluid a couple of times and it came good. I’ll probably convert it to 6 speed whenever the transmission finally gives up the ghost.
