What part are the bolts the hold on the wheel???
Wheatley098
30
Australia
Commodore VE SSV Ute
Searching high and low for them I need to get a few new ones because I cut the other ones off due to a stubborn bolt
eBay link or part numbers would be awesome!
Commodore VE Omega 08 Wagon
Rear drivers side
PIR4TE
Banned
AWOL with Ari
Black Pearl
put VE wheels studs in ebay
first items that pops up is a longer version at 79mm. Forth items is a standard replacement at 58mm long
ve wheel studs | eBay
should be able to get them for $5 each compared to $22 each at Holden or autobarn
Those are quite a bit longer, will stick out 2cm like a scythed chariot!
Perhaps just spend the $40 and source from Holden ASAP.
ducker85
Narnia
09 VE clubbie R8
Those are quite a bit longer, will stick out 2cm like a scythed chariot!.
yes the first item is 21mm longer then standard. More to the point I was pointing out to the OP how easy they are to find when you call them the correct name. My wheel studs are 71mm (13mm longer) with alloy nuts and look fine.
Standard size is 58mm so buy those. Or just let your mechanic sort them while he repairs the car.
