Is there much to modify on the vs v6 fan to fit to v8 radiator? Are radiators similar size?I really like simple yet factory looking vs series 3 2 core radiator ($100) with vs v6 thermofan($40-$50)...fitted it up to a few cars works a treat with 85a alternator although cars used it with were v8 conversions so wiring was already there just had to get memcal tune.
Have done au fans...work awsome so too would fg/bf single which look neater just need to upgrade wiring & alternator to get most out of it.
Must admit only tried vs s3 radiator & vs v6 thermofan on vp v8 ute as wanted engine bay to look nicer & curious to see if would notice difference to clutch fan...does rev quicker.
Is there much modification to fit AU fan to VS 304?I used AU Falcon fans on my 383 VS Calais. You need to (carefully) trim the AU shroud to get a good airtight fit. Others have used VT fans and even Mondeo fans. Plenty of posts on the subject in the past. Do a search on "thermo fan 304"..
Thank you, so leave it original.Bf/fg fan or original clutch fan is your only option especially if you want to retain a/c and have it work properly on very hot days.
Otherwise you can try other options but performance/ease of fitment will be compromised. Consider physical fitment, aesthetics and electrical load.
I’ve tried a number of configurations in a daily driven vehicle with ambient temps of up to 47 degrees under a variety of conditions (low speed, high load etc including towing).
If you’re really pushing it (high load, high heat for extended periods), the clutch fan is essential in a commodore vb-vs commodore. The radiators are just too small for the cast iron 304 to sacrifice airflow.
