gtrboyy
- Jan 25, 2006
- 4,305
- 2,816
- 113
- vt ss & lc gtr
Knock sensor is junk,most tunes end up having them disabled for various reasons.
How did you you work out 10:1 compression ratio? Got pics of piston in bores? Cam timing?
Pistons would need to be flush with the block,most sit down bore without decent deck skim unless been machined before or perhaps using chev pistons or something weird.Something amiss.
But yeah baby 268 not much more than standard so if comp is hiked up a decent amount it wont like baby cam/banana combination....most do the opposite cam too big for stock low compression
A good stally won't hurt drivability at all...2800 lockup & 3.45/3.7 diff gears would make nice all-rounder
Cam wise you'd be looking at 284 or better yet modern day version of it from camtech
Off the shelf tunes only work well when it's tried & true combination that's been done a million times otherwise if done something wrong or tried to be different then road/dyno tune &/or troubleshooting required.
I'm surprised you were sold the 268 when even a 276 is tad small for stock 304,just sounds nicer.
