Wheel Nut Sheared
ProbablyRaging
Drop Bass, Not Bombs.
FUNK, Uptown
Vroom Vroom Car
Does any one have a method to removing sheared wheel nuts? I've tried the old towel trick but that didnt seem to work. Rattle gun wont work. Tried a size small socket still no good. Cant use an angle grinder either because the nuts sit deep in the wheel itself.
I had this wheel off the other week but when rattle gunning it back on it must have shaved away at the shape of 2 of the nuts. Now I just cant grip the nuts properly (no homo).
Calaber
Nil Bastardo Carborundum
Lower Hunter Region NSW
CG Captiva 5 Series 2
Try drilling down through the nut on both sides immediately adjacent to the thread then using a slender sharp chisel to split the nut. If they are standard wheel nuts, they should only be mild steel and drill easily.
It might cost you a stud but they are pretty simple to replace.
ProbablyRaging
FUNK, Uptown
Vroom Vroom Car
Sounds do-able. Ill see if anyone else has any other idea's first. Cheers!
_R_J_K_
Zenki S14
I know it's a bit late now and I'm not having a go at you or anything, but I've read a fair few times on here about people going to tyre shops and rattle gunning them up so tight they can't be undone at home with a crossbar.
Something to think about, is that if you were on the side of the road with a flat tyre, would you be able to get it off with hand tools?
Tree cutter
Tree cutter
Mt Gambier SA
VX Calais SuperchargedV6
Try to get hold of a Metrinch socket. They look like those damaged nut mover things internally so they drive on the flat part of the nut instead of the points.
Tree cutter
Tree cutter
Mt Gambier SA
ProbablyRaging
FUNK, Uptown
Vroom Vroom Car
You could try bashing a slightly smaller socket onto it.
Weld another nut on top of the rounded one.
Or this......10PCE Damaged Fastner Bolt NUT Remover Free Postage | eBay
Ordered a set of these. Hopefully they get the job done! Thanks mate.
They should do the job, cheers mate!
ProbablyRaging
FUNK, Uptown
Vroom Vroom Car
All good mate. I dont think its because i rattle gunned it on too tight, just too many times haha. I was able to get the other 3 off easy as normal, but the other two have been shaved away and rounded, probably because ive hit them with the rattle gun about 5 times in the past week alone lol.
Cheers!
Cheap6
VP Exec
Alloy wheel? It depends on how much space around the nut you have to work in and how deep the nut is in the wheel but I have undone a nut like that using a cold chisel and hammer to turn the nut on the stud. It's easy to damage the wheel so a few layers of masking tape on the wheel and on the chisel would be wise. Maybe a cloth held on the wheel also.
