Ron Burgundy
- Jun 3, 2004
- 4,826
- 4,303
- 113
- Location
- NSW
- VF II SS
Going through the list of issues with my car I thought it would be interesting to list all that went wrong with it in less than 3 yrs since new. These issue really turned me off from Holden...
JUNE 2016 VF II SS
• Rattling noise on cold startup since new - dealer 1 & 2 said this was normal
• Coolant leak - crossover pipe
• Oil leak - rocker cover - new gasket
• Oil leak - rocker cover - again
• Engine replaced by Dealer 2 due excessive piston to bore clearance - 2.5yrs after problem was reported multiple times
• Exhaust leak - driver side - gasket replaced
• Muffler leak - pass side - muffler replaced
• Harmonic ballancer noise/wobble - balancer and belts replaced
- Service steering column warning light - poped up once and disapeared
- Service ESC poped op once as well and disappeared
-Horizontal lines on reverse camera - under investigation
• Dealer damaged the front bar - tried to conceal it by touching up, did not tell me. Promissed to respray the bar but did not.
- Dealer 2 always calls after I drop off the car with standard list of things I should have done - throttle body cleaning, wipers, cabin oil filter, brake pads....Mind you nothing wrong with anything above
All work was covered under warranty with some negotiations needed for engine replacement.
On a positive note, the car is perfect at the moment.
Let's see what's next
JUNE 2016 VF II SS
