I could post a 200 page essay on what is wrong with this post but I can't be bothered right now. I'll keep it to a few lines. To say rock hard springs = better rear grip is 100% wrong. Like **everything** it's a compromise. The springs and dampers are supposed to control the tyre and keep it in contact with the road. To be honest - most of these ultra low (and lower) cars are a menace to itself and every other car on the road.
Reaper
I said rock hard springs = better rear grip ?. You must have read something i didn't write ?.
I actually wrote ultra low cars are all show, more the super low height is show with handling. Those cars height is just below fe2 factory sports suspensions.
I'm not sure what you seen but i can't see what your getting at, since I'm not sure what your saying has anything truly to do with my post. If it's just a rant fair enough.
One other thing about increasing dampers rate and cutting body roll. Lowering your car will give you better centre of gravity and does increase grip. Sure it might also cost you in steering or other areas, but it does increase grip.
Keeping that standard ride height whilst using larger away bars and stiffer springs might increase grip and rebound for better contact of road. But that lower height better centre of gravity can't be emulated with the standard height.
Look there is plenty more behind lowering a car then just looks. Some of the best handling cars (using commodores as an example) sit and ride best lowered around 30-35mm from standard. 2mm increase in sway bar thickness, sportier shocks, still enough room for the springs to work it handles at its best. Set of 17" rims you got yourself a very capable handling car. Adn i see nothing wrong with lowering cars, i see wrong in 60-70mm lowered.
