Yeah it’s the supercharged v6. The ve cammed Ute would need a lot of effort to run that sort of time with the tune that’s in it at the moment + the perfect launch. The Audi u just set it in dynamic mode and press the accelerator and hang on.
Mike it sounds like you need to tune your VE properly, then consider trans calibration to match your tune. Hardly anyone does, so yeah a lot of piss poor performing VE/VF huffing about.
However your cammed VE even with BS tune is at least 300rwkw (380 kW), vs litter R5 less than 180awkw (245 kW). BTW that’s the shy end of the spectrum, a cammed tuned VE is typically 320rwkw (410 kW), with tuned (ported) bits 350rwkw, and the upper range being 370-400rwkw (470-510 kW). So you can see how it is sort of letting down the team a bit tarring cammed VEs with the lacklustre of your state of tune, when a tidied VE on a bad day smokes all and any Audi 5 Series including the latest RS5 TT?
I test drove several before I bought the VE, settled on a faster yet less busy mode of A-B.
At 300rwkw you should definitely click in the low 4s (even with AC on)! At 370rwkw you are at the limit of street tyres to 100 in four seconds flat. That’s one gear change, zero spin, like you said press accelerator and hang on. Cue to 1:50...
Perhaps your tune and setup is crap, perhaps your transmission of same is crap. Perhaps, just like hopping into a Golf R, the difference is purely experiential and not played out in actual results ie sporty feels fast.
Perhaps the answer is with driver mod - driver not commanding 100% power because the transmission is wild and terrible - but like racers of the Minis of old you are able to commit more power more of the time when it is predictable and more controllable.
I think the difference is just a matter of tune, transmission and tyres. In the case of the RS5 being near $200k, seems a folly not to “sort” your VE with trans flash, Torsen diff like the Audi, and $500 a corner tyres, like the Audi.
