FRont struts are the same sway bar mounting from VT to VY. From VX Series 2 the sway bar end of the link pin got a ball jointed end and then the VZ changed to a ball joint type end at the top as well so the mount on the strut is different.
Also VZ engine is lighter so the spring rate may be different. You could probably use a VZ strut if you changed the sway bar as well?
