Decicrate
Thanks Barry! Oh I'd like to see how you wired your VDO corrector, i ended up buying one from Mal Wood and the way i've got it working at the moment means that the 2 speed sensor wires at the ECU arent connected to anything at all! When i got it, it was calibrated for 3.9:1 diff gears and so i had to change that, but the setting it's on now for my 3.5's is nowhere near the 3.9's setting.
The thing is with the VDO box is that it also converts the signal type that is output by the T56's speed sensor (magnetic reluctor), to what the original getrag's speed sensor would have output (hall effect). Therefore with the T56's sensor connected to the ECU, it receives a signal that it can't really make sense of. It's still a bit of a headache for me lol!
If you wouldnt mind i'd love to see a diagram of how yours is wired! I think you already told me how to adjust the PPK value, is this done with Kalmaker, and are there other known ways to do it?
Ok just so we are on the same page.
Your VDO corrector box should be wired between the ECU and the speedo, NOT between the gearbox and ECU. This is a separate loom so to speak.
Now gearbox to ECU.
Seeing that yours was a GETRAG, the speed sensor wiring is two wires.
Cut the plug off the loom and connect wires to the T56 speed sensor.
When Dick does the tune, he should be able to check that the Vehicle Speed Sensor is set to High Resolution.
Then the table I adjust to get the road speed and the ECU speed to be the same is called VAR:MPH:MPHFAC, this is a Kalmaker table and will have a different name depending on Dicks software. Getting this correct will have no effect on the speedo read out on the dash, this is the ECU only. My Vehicle Speed Sensor is set to 40 Pulses per revolution.
To work out the value for the VAR:MPH:MPHFAC is 512*final drive/tyre diameter in meters.
6200rpm does sound good! Is that where yours is set? As long as you think it wont do anything too crazy to the internals at that rpm then thats what i'll ask for in the tune! Obviously Dick will tell me what rpm he thinks will be good as well.
I have mine at 6100rpm at the moment, will be going a little higher next tune.
Man 4000rpm must be annoying for your LS1 MAF to be running out! You can't take it any higher until you go bigger or MAP based atm, is that right? I guess i'll be getting a MAFless tune done then!
I can run a 100MM MAF which will solve the problem, but MAFless is the logical way to go.
The reverse lockout would be great to get working with the ECU but yeah i think it will be hard to do. I've currently got mine wired to the brake pedal, but I've noticed that when driving with the lights on but without my foot on the brake, the solenoid manages to get enough juice to open up occasionally! It only does it with the lights on though, prehaps i'll have to add a resistor inline between the brake pedal switch and the solenoid or something. It'd be better to be switched by speed rather than having to have a foot on the brake.
In the later models it is run via a speed switch which I think is operated from the BCM.
And a 61mm pulley, are you serious? Apparently on a 3.8 that'd theoretically push 20psi! While i'd like to, i dont think thatd be a great idea un-cooled would it? I'm keen to put a smaller one on for the time being, but i'll see what Dick thinks too.
Sorry I forgot that your was not cooled,,, forget i said 61MM
hope this helps
