Badgerman
- Mar 7, 2016
- 6
- 0
- 1
- Age
- 39
- Location
- WA
- VT Executive
Hi everyone. This is my first post here, so I would like to to say hello.
Now my problems.
I have Holden Commodore VT II 3.8 V6. It has just above 200kkm on clock, and it is a good time to change oil and maybe few more things. According to Service Manual, I should use 10W-30 oil (SJ GF2). Alternatives are 15W40 or 20W50 with SG, SH or SJ parameter. I preffer to use full synthetic (previous owner has done that and said that I should continue this). It is not so easy to find good oil with those parameters.
I have found Mobil 1 - 10W30 Full Syntetic, but seller wants AU$96 per 5.7L. I have found also few more, that initially seems ok:
Lucas Oils 10128 Synthetic High Performance Motor Oil 10W-30, 5 L It has correct viscosity, and SJ norm, but I do not know about this manufacturer. This is for about AU$76
next one is Castrol Edge Engine Oil - 10W-30 5L for only AU$60, but I am not sure about its parameters such like API SN/CF (instead SJ) or ILSAC GF-5 (instead GF-2).
same here: CASTROL ENGINE OIL GTX MODERN 10W30 5L for AU$40. It is not listed what kind of oil it is.
I have found also this one Gulf Western Oil Premium Energy 10W30 6LT Energy Oil for only AU$38, but this is a suspicious price. I am not sure is it full or semi synthetic. Also company is not well known.
I do not have any idea why all manufacturers recommend 5W30 oils. There is nothing like that in car's manual.
So here are my questions:
1. Wchich oil from that above?
2. Maybe other (but I preffer still full synth)?
3. I have found that two lenght of oil filter is listed for my car -79mm and 129mm. Currently I have shorter one. Both cost same money. Are there any advantages to install longer one ? Any contraindications?
4. K&N filters (white series) are fine, or I should pick other ?
5. What are change intervals for spark plugs, spark wires, oil (when synthetic and car runs in City only), oil filter and fuel filter?
6. Is there everything more that I should check/replace (I mean periodic changes, not worned elements )
7. How can I cancel "Service 200000" from my clock ?
Now my problems.
