Alloytec Timing Chains replacement
skootaroo
VS wagon
So did Anyone ever do a full writeup for changing these timing chains?
skootaroo
VS wagon
Does anyone know how to unhook the wiring harness from the drivers side rocker cover?
Passenger side is a neat clip arrangement, easy but the drivers side seems blind and it blocks some of the rocker cover screws.
pHatVE
VX SS - Series 2 - Manual - 305kw
Hi Guys,
first time on this forum but got a quick question.
Has anyone ever come across any problems after they changed the timing with sensors still going off? I currently did the timing chains and gears, and i am getting error codes popping up on my ve v6. the codes im getting are P0014, P0021 and P0024. Indicates that the camshaft position sensors are faulty on bank 2(Both) and 1 on bank 1. Replacd both on bank 2 and had the software updated recently, but the error mesages are still there. Anyone ever had this problem with the alloytec engines?
Chaney
VE Omega
Hello, did you replace the tensioners while you were in there? I had to wait for about 2-3 weeks for Holden at Newstead (Brisbane) to get some tensioners from the states. Pretty much no Holden in Australia had many left when I was doing mine. The guys there told me there was heaps of failures, therefore the shortage of this part, also why they have a revised part number. Not sure if this will throw a code or not tho.
The other thought is did you double check the timing alignment. I must have checked mine 10 times before I put it all back together. I also turned the engine over a few times manually, then backwards to the start just to check nothing jumped.
Good luck with it.
Hi Guys,
Chaney
VE Omega
If anybody out there doing this job in the Brisbane area wants to borrow the flywheel locking tool and crackshaft socket (not really needed), harmonic balancer puller plus a tool I made to push the balancer back on, I'd be happy to share.
Cheers.
pHatVE
Good luck with it.
yeah had the tensioners aswell. we did the whole works (chains, guides, tensioners and gears) even changed cam positions sensors because the code kept popping up.
not sure if this can cause it but we changed the oil and there was heaps of sludge inside the engine. put a bottle of sludge cleaner to drain it out. put new full synthetic oil (penrite 5w-40) and then have been running her for 1k. were guessing it could be the oil and sludge inside the engine that could trigger the codes to appear. gonna drain this new oil in 1.5k later with 2 bottles of sludge cleaner and then try.
HOlden advised after updating andf flashing the computer that the cam actuators could be faulty. Bit odd this happening after changing the timing chains and stuff. Any idea what else could be causing these codes to appear and also anyone ever have the same issue?
dumb ford owner
newcastle
xr6
hey vt_on_20s, man we just done the chains in a vz sv6 and now its all back together the car turns over really slow even with a fully charged battery, u wouldnt happen to have any idea wat is goin on with it?
oh and BTW, the procedure u just stated,( turning the cams so the flat spot on the rear the cam is facing the top then installing a chain/guide, then turning the crank to install the next chain/guide etc) would that reset the cam timing back to stock as i think somehow the timing is retarded.
cheers in advance
rumper
www.brewersupplies.com.au
VF Maloo
Done a couple now. You don't need any of the so called special tools and you can get the full chain kit for around $650 from ebay. Chains, tensioners, gears and runners
Mad Pete
58
sydney west
2005 VZ SV6
I am currently rebuilding by late 06 alloytec out of a vz (WD4).
I went to holden to price all new parts including timing chains, tensioners, seals, head gaskets etc.
They have me a written quote for just under $2,000 however this quote came with all the part numbers aswell.
Now, Holden is part of general motors, they're part numbers are are same world wide and this engine is also used in a 06 - 11 Cadillac STS.
I am currently waiting for my order from GM Parts Direct which cost me just under $600 AUS shipped. which has exactly all the same parts and part numbers.
So with the exchange rates as they are now i would highly recommend importing any parts at this stage in time.
spac are these the numbers?
12597307 Primary Timing Chain $37.71
2-12589011 Secondary Timing Chain $29.20each $58.40
12597413 Left Idler Gear $30.91
12597414 Right Idler gear $29.13
12590921 Crank Gear $25.02
12600461 Left Side Secondary Guide $21.70
12597418 Right Side Secondary Guide $19.91
12597417 Primary Upper Guide $20.67
12623513 Left Side Secondary Shoe $21.47
12623514 Right Side Secondary Shoe $20.76
12609261 Left Side Tensioner $68.96
12609259 Right Side Tensioner $44.01
12609263 Primary Tensioner $67.61
12641260 Right Side Valve Cover $140.21
12647768 Left Valve Cover $136.65
12640448 Oil pump $160.10
12566429 Water Outlet Gasket $5.24
12584040 Water Outlet o-ring $5.14
12634750 Water pump Gasket $$5.28
12622550 Water pump seal $12.70
12608750 Front crank seal $8.59
4-12593717 Cam actuator seals $4.48each or $17.92
12598158 Upper and Lower intake gaskets $67.96
12378521 RTV $15.02
25177917 Oil filter cartrage $7.84
Sabbath'
Redblock Jesus
80 Series// VFII Black Edition
Why are you replacing the oil pump and valve covers?
