lout
- May 13, 2006
- 5,567
- 4,277
- 113
- Age
- 60
- Location
- Langwarrin Victoria
- VXii Executive V6 , VYii Adventra LS1
ok to make up for my earlier post
try charging the battery
remove serpentine belt
then start engine
once engine has started , turn charger on again
only run for a few minutes as water pump will not be circulating
this will eliminate if problem is voltage related or additional load on engine
when was throttle body last cleaned
sounds like furl pump/ fuel filter to me
new does not mean good
then start engine
