The L67/M90 set up has 2 types of boost controller (use the term very loosely). The boost bypass actuator sits off the side of the blower and it is controlled by vacuum. When there is a vacuum state the boost bypass valve will be open so there will be no boost generated.
It is done like that as you do not need boost when just cruising along on light throttle. This keeps the blower temps under control as well as saving fuel.
When you put your foot down and there is little to no vacuum being generated, the valve will close allowing the blower to create pressure (boost).
If the valve is only part way closed you will make less pressure as the bypass is allowing air to bypass...
The second controller is the boost solenoid, this is controlled by the ECU.
It is there to bleed of boost if the ECU sees certain states, high temps, reverse gear and so on.
Most people delete the boost solenoid to stop that happening.
You could use the boost solenoid to control the total amount of boost via the tune.
It's not possible in the standard tune but if someone was smart enough to alter the factory tune, you could in theory switch between low and high boost with a simple dash switch by running a smaller pulley to achieve a higher boost and then use the boost valve via the boost solenoid to reduce total boost when in low boost mode.
I believe you meet the 2 criteria; therefore, when will you be doing said Hi/Low boost mod aye oke:
i too would like to see someone complete that would make a real good add on to a sleeper
