Yes this is true but its early days. Hopefully governments wake up early and force compliance such as Apple converting to USB-C to save on phone charger waist.
EDIT: Maybe not using all the same battery but at least creating a standard where the battery is repairable/exchangeable
My observation is that companies start out doing things in a proprietary way, but eventually like to standardise things to mitigate their individual (company) risk. Set up a standards committee, and get them to publish a standard and that becomes the ‘best practice’. All hell can break loose after that and legally all the companies are shielded from litigation as they followed the ‘best practice’ at that time.
Standardisation seems to happen at a snail’s pace. Firstly, the charging connector (and protocol it uses) will become standardised but it might be several different standards (remember VHS vs Betamax, compact cassette vs 8-track, Compact flash vs SD…). Eventually one standard seems to win out.
I suspect that battery packs might also be standardised, or at least, the ‘format’ of the cells used within the pack will become standardised to allow an aftermarket rebuilding or reconditioning industry to develop.
There was a company (called Better Place) that did try to set up a standard battery pack for EVs and had rapid change stations that could swap a battery pack in minutes. The idea was to allow battery changing a bit like swapping a LPG gas bottle. They also proposed a rental scheme for the batteries - which also had the advantage of reducing the upfront cost of EVs. Essentially you’d buy the car (sans battery) and purchase a rental plan with Better Place.
Better Place went in to receivership during one of the numerous ebbs and tides of the ICE to EV transition cycles.
