Further to my last post, an example of 'fact' vs 'hypothesis'.
Water boils at 100C, correct? Well, yes and no. If you boil water, and measure its temperature 1000 times, and its 100C every time, the theory is proven, right? Again, yes and no.
All you have done is proven that water, when boiled within a particular set of circumstances, did so at 100C 1000 times and other temperatures did not occur. This would appear to be proof... but its not, because there are other unconsidered factors.
If you are unaware of these factors, you are not going to consider them as an influence. However, now we know more than we used to, we have to justify our conclusion with the statement 'at sea level in normal atmospheric conditions with distilled water' for our conclusion to be valid. Even then, there may be other factors which can change the 'fact' occasionally that we aren't even aware of.
I can state that water boils at 75.5C, and I would be approximately correct.
However, I would also have to add 'at 8000m above sea level, in normal atmospheric conditions, with distilled water, and assuming there are no other influential factors' for this to be a scientifically valid statement.
Of course, its not as simple as that either.. to make that statement I also have to define 'normal atmospheric conditions' ,what constitutes 'influence', and just how highly distilled the water actually is.
Of course, how accurate my measurement is also depends on how accurate the equipment I am using is when measuring the water temperature, the altitude, the air pressure, the ambient temperature, the air composition, the purity of the water and the many other factors that form the available data. Even the wind speed is a factor, the tiny amount of cooling provided by a puff of breeze over the water is significant in a truly accurate test, because its variable.
With all available data, within the abilities of our equipment and the availability of physical evidence, evolutionary theory is our current best guess. We haven't been able to disprove it despite having tried our hardest with our best available science ever since Darwin first wrote the book. We did try really hard too, so many people find it unpalatable to have similar genetic origins to the apes (and as stated by someone earlier, we are not descended from the apes, we just have similar origins. We are cousins.).
That means it could yet be disproved, but for now that's the best theory and the one I am going with.
