I've had the same problem in my VE ute. Tried clearing the code, came back, replaced the oil sensor for $170 and it still won't go away. Any other suggestions?
posting in here because its spidered by google when searching this fault
so i hooked up an elm327 obd2 to my vz 175 as im getting this svs warning periodically
then ran up torque on android but its saying no errors listed in ecu
is this a normal error that ill be able to extract or will i need to get a mechanic to get it out?
Service vehicle soon is not a 'Service Reminder'
its a fault thrown up, usually an oil pressure sensor. Get someone onto it with a diagnostic tool (Scanner) and see what comes up. My guess as i said before, oil pressure sensor.. $40 from repco, 10 second replacement
