I use to be indecisive but now I'm not sure......
I contacted Autotech Engineering again to revisit installation of the RaceTCS
I've been talking again to the guy who had one installed on his LS1 swapped R33 Skyline, he said to "do everything I can to get it fitted"
He went through the whole thing with HPTuners trying to limit power in the midrange, he said it was problematic and was never on point, trying to limit torque in the tune when different rubber was used, or if the road was dry, black top, concrete, prepped or wet was impossible, he then fitted the older version from Racelogic, got the tune on point, then set the TC to what slip he wanted
He stated that it was a weird sensation in the wet to just mash the pedal with TC set to minimal% slip and the car just accelerating off like a cut snake, or set it to a larger % of slip for a little fun
He said it happens so fast he doesn't really notice it either, the car just leaps forward in the wet, accelerating, which sounds awesomeballs to me
It starts by fully cutting one cylinder, but, it doesn't just focus on the one cylinder, it cycles through all 8, so a cylinder is only cut for one injection event, and it happens quick, as in millisecond quick, once it gets traction, or the % of slip dialed in it gives power
If it needs to cut more power, it will then cut 2 cylinders, again, cycling through each set of cylinder
It doesn't really matter if I'm running drag radials, or street tyres, 0% slip, is 0% slip, and 5% slip will still be only 5% slip, not matter what rubber or tyre pressures you use
Plus you can turn the dial to 100% slip for the pre stage burn out/smoke show/trailer burn out
I talked about actually selling the RaceTCS because it has been sitting on my shelf for the last year, I ended up getting quite a few offers on it, they said I was mad for not installing it, and it is perfect for my platform, because the stock ECU is fine for engine management, and that paying upwards of $10k for a aftermarket ECU, getting it installed, and all the tuning involved for what in essence the RaceTCS that I already own can give me, all for a minimal initial outlay, then installation, "all the power with dial in wheel slip"
It can go from 0% slip, to mad skids, with 5 different % settings of my choosing in between, like 0-3-7-10-20-100%
And easily programmable, apparently, even a Muppet like me
This is what I'm talking about, and has been sitting on my shelf whist I procrastinated>
http://www.racetcs.com/
