soft/low brake pedal
Vin999
SA
VSedanS
Evening people,
I've had the master resivoir off, cleaned the gromet seals, reseated them with a slight smear of red gasket goo. Also I've cleaned and installed the VS resivoir onto the master cylinder (finally), also with a slight smear of red gasket goo. Making sure it doesn't block any ports...
I'm leaving the gasket goo to go off, then I'll refill. I'll update in a night or so,
Pete
Don't worry to much about your goo experiment on the rubber seal it aint going to do any harm.
Since you have taken reservoir of, chances you might have introduced some air into m/cylinder, so it will pay to bleed m/cylinder at the lines before you bleed the 4 wheels again.
With all the issues sorted once you bleed the whole system again you should be right this time. cheers :)
Lex
Geelong Victoria
VT Executive S1 V6 6 speed Auto Wagon
flexible rubber hoses
Can you still buy the Holden flexible rubber hoses?
I was under the impression you can't buy them anymore?
That is why l used the braided stainless steel flexible hoses.
vc commodore
Like the Leyland Brothers
VC, VH and VY
Don't worry about the goo, it won't cause any harm? Have you seen what happens with goo, when it gets into any fluid style system? Obviously not, with this comment....But just to help out, it tends to block up any passage ways...And blocking up passage ways prevents fluids from flowing through...But hey, not having brake fluid flowing through isn't a problem
Having fluid weep out from under the reserviour introduces air into the system to begin with...Hence the low brake pedal...So of course, re bleeding it is a must.
vc commodore
VC, VH and VY
Not sure about factory holden rubber brake lines, but definately aftermarket ones......
Immortality
Staff member
Sth Auck, NZ
Can you two drop it, it's getting tiring for the other members.
shane_3800
35
places
vr commo
Condensed Version: from start to hopfully nearly finished. A quick breakdown to where I am up to today...
Hi, I had a next to no pedal to start with after car sat for a few months.
Done VR master cylinder internal pistons seals (new), caliper piston seals also new on all 4 calipers, not alot better if any pedal wise.
Some times pedal would feel like it's getting better, but wasn't sure if my leg was getting tired pumping the pedal.
Pedal soft and spongy. Found some minor brake fluid leaks, remedied those.
VR booster making a woosh/hiss sound.
Since then, I've replaced the front brake hoses with new rubber ones.
Have upgraded to a VS booster and VT/VX master cylinder, just got to determine if it's a ( 1 inch) master?
Last night I found a weep/leak booster end resivoir - fluid port, which I'm in the process of fixing shortly.
Pete
So you have VT front calipers? My VR never felt good with them running a VR master. VT-VX master should change feel.
Immortality
Staff member
Sth Auck, NZ
Thread cleaned. Lets keep this on topic and leave personal issues of the forum.
