This might sound like a silly question, but instead of swapping over the pins, wouldn't it be just as easy to cut and reverse the wires?
I have a Berlina and severs tinnitus, so the bottom end ( below 13k)is all I get to hear. This sounds like a perfect fix for me. (too much volume is quite painful).
Not a silly question at all! You are right. It is effectively the same thing however, swapping the connections is a neater solution and that is really the only benefit particularly if you ever want to reverse the mod and not make it obvious.
Sent from my GT-P7510 using Tapatalk 4
Next problem.
It appears that even though my Berlina is fitted with the Blaupunkt sterio, there is no amp near the battery and from what I can see, no base speakers on the back shelf.
It is a dec 2006 mod with factory dual fuel.
Anywhere else I should be looking for the amp?
