… the filter and ATF was changed in Jan /2023 service @ 137,457 km although this was suppose to be done @ 150,000km…
That’s good to know something was done by the dealer at 137k kms
I’d guess that the dealer service was just a pan drop where the torque converter would still be holding a few litres(?) of 137k km old fluid. After your pan drop, that old TC fluid would mix with your new pan fluid which is why it would look so dark after 15k km of driving with the odometer now at 150k km. Just rephrasing and adding to what
@Immortality said in
post #136
As is, another couple of pan drops and fluid changes should see it finally a clean pink, else you can use a flush technique to replace all fluid
Been a while since I’ve watched the above so can’t remember when within the process he uses when he changed the trans filter. Ideally the trans filter should be changed as a last step, to be sure to be sure, using a pan drop technique though that would use more fluid…
