Skylarking
- Feb 3, 2018
- 10,222
- 10,786
- 113
- Age
- 123
- Location
- Downunder
- Commodore Motorsport Edition
For what it’s worth, the pan looks remarkably clean along with the magnet that doesn’t have too much smutz on it considering the transmission has travelled 150k. One would have to wonder whether the fluid has actually been replaced some time in its life by 3rd party and the book simply not stamped.was interested to see the inside of the pan after 152000km and no filter or ATF changes based on Holden servicing
It will be interesting to see the filter opened up along with some better shots of the fluid colour.
As for the seal, I've heard it’s a bugger to replace and you have confirm the fact. I’d be worried about scratching the bore where the seal lives which means I’d take more care and probably do a better job than the Holden service monkeys who would rush through the job and/or just not change the filter.
One has to wonder why GM went so cheap on the design and didn’t go with a filter design with a flange and flat gasket with a small bolt or two to hold the filter on (or better still just a pick up pipe and an external spin on filter)..
One also has to wonder about the lack of trans sump baffling (and I’ve not heard of a dry sump transmission) given the limited edition performance versions that are track qualified. I guess than just reinforces the view that a true performance transmission is shifted by hand
