- Apr 15, 2006
- 22,694
- 20,727
- 113
- Location
- Sth Auck, NZ
- HSV VS Senator, VX Calais II L67
I'm not one for posting about a oil change, however having just completed oil and filter change on the VE V6, and VF 6.0 litre over last 2 days, I was comparing the difference in Ryco filters for VF 6 litre and the older VN 304 V8 which we just upgraded to remote filter.
However filter is same size just different threaded screw, would I thought over the years the filter capacity would of increased
I think filters have gotten smaller over the years
Just look at a Holden 308 filter (Z30) and then 304 filter (Z160).
One argument I heard for smaller filters was that once the engine was shut down and oil drained back from the filter, with a larger filter it would take longer for the filter to fill and therefore longer before you got oil pressure. Personally, I never had issues with building oil pressure on a 308 or old 202 which both had larger filters and with the anti-drain back valve modern filters have this is certainly not a problem.
The problem with LS motors/filters is location. You can't just fit a larger filter as it will hang down lower than the oil pan and the last thing you want is to hit/damage the filter and loose all your oil/pressure instantly.
I am very much a believer in larger oil filters but that is a discussion for a different thread (which I'm sure we've had somewhere).
