Draimond
- Aug 28, 2008
- 285
- 260
- 63
- Location
- Brisbane
- VS V6 Executive
I mean we all start off as bolt on guys. Depends how far you want to go / do yourself / learn and how much money you want to save in labour.
I did some of the HP academy courses online, watched all of the skid factory and spoke with people like the guys at nugget garage and haltech to learn what I've put into my build.
I'll have my full V6 turbo engine wiring harness diagram up on the forums by December, it just needs relay diagrams and to be checked off by haltech. I'm sure it'll be useful to anyone here on this same kind of journey. If you can crimp 1 wire, you can crimp 150.
As for the rest of the build, have a look at my build thread for parts and cost insights. I'm about halfway through the work and have purchased most of my parts.
Once I've got my own setup tuned and working I would be more than happy to help you or anybody else through any part of the process including step-by-step wiring if needed.
I don't know how far you can go with factory ECUs, particularly with using them on different cars and with different configurations. Can an LS1 ECU even be "tuned" to run 2 less cylinders?
Either way, you'll have a much better idea once you speak to someone who's got experience with the V6 Commodore platform.
I have my doubts about 250rwkw with a factory ECU and a stock 4L60E auto on 98 octane long term. Especially without wideband O2 control ... You could go full 1990s spec and run a seperate pyrometer next to the boost gauge on the A pillar to try monitor EGTs and air/fuel mix manually.
The theory is that a rising rate fuel pressure reg should be able to get into the correct ballpark for air fuel mixture mechanically and without any ECU assistance. But you're putting all your faith on a "dumb" mechanical system to give a rough fuel quantity.
Speaking of dumb mechanical devices, your wastegate won't have a boost control solenoid with no (PWM) pulse with modulation outputs from a factory ECU. Go to YouTube and type in "Driving for Answers All Boost Control" to see why a boost T is not ideal in 2020+
Ask anyone who made big power 20 years ago and they'll tell you how jank their setup was compared to the technology we have today. That technology that enables us to make the same power today, but with high levels of control, accuracy and safety. And still, really it's E85, wideband and an ECU that makes boosted NA a thing at all. I dunno man, I just... You find me someone who says who can do it without an aftermarket ECU, give me their phone number and I'll argue with them till they say, ok you're probably correct. If not I bet the phrase "you can get away with" will come out a lot.
You did say you don't want to do things twice. I'm not saying right or wrong. I will say, there is A way to do it and there is a Better way to do it.
