@vc commodore , I understand what you’re say but ‘simple fact’ can be a moving target when ‘bureaucrats’ are involved, specially across states (which aren’t consistent).
As is, many 4x4 lift companies were also certain in their interpretation of the modification rules. QLD and WA suddenly took a strict interpretation of the rules on vehicles with ESC and mayhem ensued. Owners who were compliant one day were being defected the next. Bureaucrats.
A strict interpretation of the rules w.r.t wheel mods as they’ve been explained to be by the regulators seems to be the safest course for any business to take, in today’s climate, where bureaucrats can’t really be trusted (if history is anything to go by).
And the kicker is defined in:
Guide to Modifications for Motor Vehicle
13.7 Modifications to Vehicles Equipped with ESC
Many modern vehicles are now being equipped with a safety feature known as Electronic Stability Control (ESC).
(ESC is also known by other terms including vehicle stability control or dynamic stability control). ESC provides motorists additional safety in terms of vehicle stability and handling, particularly in difficult situations where loss of control could otherwise occur.
ESC uses computer technology to assist the driver in maintaining control in emergency situations – particularly when executing avoidance manoeuvres involving sudden swerving and in cases when the vehicle begins to slide and rotate sideways.
Braking is automatically applied to individual wheels, such as the outer front wheel to counter oversteer, or the inner rear wheel to counter understeer. Some ESC systems also reduce engine power until steering control is regained.
ESC is programmed by the vehicle manufacturer for the vehicle to which it is fitted taking into account a number of design parameters such as brake, engine and transmission performance, tyre specifications, steering systems, suspension (type and performance characteristics), mass of the vehicle and weight distribution.
For modification codes contained in Section LS of VSB 14, evidence should be obtained either from the vehicle manufacturer or through testing to determine the impact on the ESC system. To remain within the scope of this Section of VSB 14, a vehicle fitted with ESC must not be modified if the operation of the ESC is affected unless the ESC system is adjusted to restore its original operational characteristics.
Similarly, vehicles equipped with ESC must not have the ESC control unit disconnected.
The above passage is also repeated in
Section LS of VSB 14. Basically it’s the clause that has thrown a spanner in previous interpretation of the 4x4 suspension lift rules. Rims/tyres are next. And a vehicle manufacturer will not help you while doing ECS testing is silly expensive (which is why the 4x4 mod businesses are making lots of noise).
