Leave it off if you like.can i leave that huge plastic cover off above the radiator?
oh gooLeave it off if you like.
It is there to stop you losing fingers and hands while the engine is running.
It may also assist air flow through the radiator and around the engine, not sure.
thanks yeh!Better than nothing!
I bought one because I took mine out and had a close look and its pretty worn with fine cracks along the outside of the seal, and Ive read on here that it fixes many problems so for 16 buck I thought Id give it a try. So if it still gets warm, do you think I should completely empty the sealant and put fresh sealant in? I wasnt sure whether to get the small 1 litre top up bottle at autobarn or the big 5 litre one? And do you know when you fill up new coolant, how do you get rid of the existing coolant in the coolant reservoir? I know theres a tap for the radiator, not for the cooling area though, not sure though.Check if yours is holding pressure first. If it doesn't then get a cap
