im thinking you took out a fuse or fusible link
was the battery still functioning when removed or did you change it because car would not start
car was completely fine was driving daily driving it and then battery died initially in my work car park, I got a jumpstart and drove it home, the next day I brought a battery and it’s the correct battery replaced it and went to start it and then a code was in the middle screenim thinking you took out a fuse or fusible link
The car sat for few days with battery disconnected. So im sure it was dry,unfortunately there are about 10 separate fuses for bcm
time to check every possible fuse and fusible link
have you tried fu's idea to disconnect battery and discharge caps and then reconnect
Hi guys the car died after replacing the battery? now the car doesn't start, acc on car lights up and all warning lights are flashing, contact the dealer etc. Plugged the scanner in and it shows ( lost communication with the BCM ) i have another BCM with different part number somewhere in the shed should i just clone the original one? Anyone have been through this before? if so what was the resolution please? TIA
Please have a look at the video belowvery unlikely bcm is fried if you did nothing wrong
have you tried disconnecting battery again since this
will check some diagrams tomorrow for fuse numbers
is the security padlock light working
