ZeroLachie
33
WN/VF Caprice V, Series 2, 6.2l
Hi everyone,
I need a bit of help. I want to put 20inch wheels on my 2016 WN series 2 Caprice. The problem is that I can't get tyres with the required load rating until I hit 265/xxR/20 which is too wide for the front.
Turns out the HSV version, the Grange has gotten away with a lower tyre load rating by having a lower breaked towing rating.
Qld transport has put me onto a gentleman who can do up the paperwork to re-rate my Caprice's GVM to that of the Grange.
If anyone would be willing to send me a photo of their 2016 Grange's Build plate, compliance plate and tyre placard they are the last pice of the puzzle that I need to get the mod plate.
Thanks!
Voodoo_SV6
58
MY12.5 E3 R8 Manual+MY16 VFII SV6+MY11 VE S2 SV6
If you don't get a response here, maybe try hsvforum.com.au as there maybe a few owners on there.
07GTS
Australia
VEGTS BUILT BLOWN E85
should easly fit 275 on the front i would have thought, unless your wheels have an odd offset
kleanphil
G.C.
VF SS-V SII Sportwagon
I had a similar problem when I put staggered 20" on mine I couldn't find a set that had the right load ratings , I ended up with 255/35/20 Haida for the front and 275/35/20 Winrun for the rear , cheap tyres but I haven't had an issue with them and correct speed and load ratings .
EDIT : I couldn't find the Haida when I needed a tyre for my spare so I ended up with Powertrac
ZeroLachie
33
From all the research I have done I would have to go from a 245/40/19 tyre to a 265/35/20.
Apparently with the extra width and overall diameter it would foul is situations like turning into an uphill driveway.
Wheels I am planning on are Koya SF04 20x9 with 35 offset for the front and 20x10 with 42 offset for the rear.
lowandslow
NSW
V2 III Monaro
Just buy a Grange tyre placard?
panhead
NSW Central Coast
Cars
Hi everyone,
Thanks!
What is the load rating, front and rear?
panhead
NSW Central Coast
Cars
I only looked at one tyre manufacture and found this, the other brands may have similar sizes.
Bridgestone Potenza S007A
245/40R20 99Y overall diameter 704mm
285/35R20 101Y overall diameter 708mm
The tyre diameter was calculated using Tempe Tyre's Tyre Calculator.
How does the overall diameter compare to your existing setup?
