Darren_L
- May 2, 2009
- 1,872
- 73
- 48
- Location
- Toowoomba, Qld
- VH SS
202's are a good, reliable engine. Yes they leak oil like any rope seal rear main engine, but if they are built properly they are a very reliable engine. The old man rebuilt one for the old HK Holden. Didn't spend a fortune, just did it right. That engine powered a fully loaded HK with roof racks and box trailer from Brisbane to Cairns and back and Brisbane to Melbourne and back without one issue. It continued running without a problem for over 100,000 miles until cancer took over the bodyshell of the HK. Reason why you hear of people having problems with any of the older engines, is because they are such a simple engine, anyone will have a go at rebuilding them, so unfortunately there are are a lot of dodgy 202's around.
don't go over the top with o'ringing bores etc unless you plan on super high compression and/or forced induction. As suggested a chemical clean,rebore, cam bearings and get the rotating assembly (ie crank, rods, pistons, flywheel & balancer) balanced. It's worth the extra money spent. However be prepared to go beyond your $400 budget to do so. But IMO it's better off spending the money on the bottom end, you can always do stuff like porting the head, roller rockers etc later. Doesn't take long to pull the head off a 202.
With a set of flat top pistons, a decent carb (I'd suggest a rejetted Webber off a Falcon), the RIGHT camshaft & valve springs (the likes of Crow or Crane can suggest a suitable cam profile & valve springs to suit your setup and requirements), your 202 should get along rather well. Everyone seems to bag the 202 these days, but seem to forget these engines powered Brocky's Toranas to more than one victory at Bathurst, against the big 351 GTHO Falcons.
