Marksboat
Hi all. Firstly I gotta say I'm so glad I stumbled on this forum. So g'day to you all. I'm a long time Holden owner having owned just about every model they ever built from my first car a fb wagon to our family vz wagon.
But my question today relates to my inboard boat with a 202 onboard.
I don't know the history of he motor but it seems VERY NICE. Someone has either started with a nice stock motor or had it reconned.
I shoulda mentioned I'm not much of a mechanic but know probably just enough to get myself into trouble, and not quite enough to find my way out again!
To the boat....I have a REAL LOUD pinging or rattling under load at higher rpms. I call it pinging as that's the best description I can think of but it's way harsher than what you'd expect from low oct fuel or timing issues. And before anyone offers the suggestion of timing, here's what also happens. I can floor the boat and she goes great but after a short (10 seconds?) time the rattle develops, gets worse and I have to throttle back for fear of something breaking. If I bring it down to an idle, it develops a lumpy 'cammy' loping idle and will often stall. After I restart it, it usually runs fine until I give it some stick. Sometimes even after being switched off for a while it won't run smooth and I've got to squirt the throttle a few times to get her up and going. Under light to 3/4 throttle she runs all day and is as smooth as silk, no rattles, blowby, just as sweet as!
I have recently replaced the points dizzy with a Bosch hei from a later motor, made sure I have full 12 v at coil which was also the hei transformer style and I used all new leads and regapped the plugs tp 1.5
mm and set the timing by ear. It starts instantly and idles perfectly and has instant throttle response.
I didn't notice this issue prior to changing the dizzy but I only used the boat once and never really floored it. On the first day out the old oil filled coil died and we had a bit of a paddle into shore! I figured this was because the old coil was receiving continuous 12 v and cooked. So I replaced it all with the hei.
I thought it could have been fuel starvation under load but the lopey idle has me stumped. I have made sure the tank has a good breather and the glass fuel bowl on the stock fuel pump always looks full even when misbehaving.
I can't tell you what the revs are as the tachometer isn't working. But I'm not thrashing it, I'd guess it's around 4,000 revs. There's still lots more left in her before she starts to ping.
Could this all be due to the lifters pumping up? I've read up all I can on this but nothing seems to sound just like my problem?
A friend who is a very experienced mechanic suggested some 26 thou spacers under the rocker saddles as a try. I just don't know enough about all this and don't want to start playing around with things I'm not too familiar with. The pcv and oil breather system all seems fine. As I said, this motor has NO rattles or noises until this point, has exc oil pressure that is pretty low at idle, and seems to be a very quiet motor!
I've read about anti pump up lifters but seem to get mixed opinions as to how well they work. If anyone else feels this is a valve train issue, would I expect any improvements from fitting new springs, and should these be standard springs, and would new standard lifters be worth a try? How much difference would oil and or oil filter make? I haven't changed either as I was told by the previous owner it'd just been done and certainly the oil looks relatively clean.
As you will understand, the motor runs cool as it's pumping cold water straight from the sea and has no thermostat so maybe the oil is cooler than in a car engine? Cooler oil = thicker oil?
I've tried to explain things in as much detail as I can so as to avoid too many questions establishing what I have and haven't done.
So sorry for the long post. But if anyone can help me shed some light on this, then I'd REALLY appreciate it.
Thanks. Mark
Ps - I should have mentioned that she loses power once the pinging starts?.
Thanks. Mark
