Good on you doing so many and fixing so many....
My point still stands...Your way has 2 toe adjustments, which is pointless
No it doesn't. Your point does not stand, I've explained why, but if I explain it to you again you will repeat what you just said because you know you're wrong.
You will just repeat what you said because you're a troll.
You're like an idiot that wears a black mask out in public.
Insidious trolling is your specialty.
I'm not taking your crap and will return serve to your looser arse.
When you add an offset bush you line it up with the top giving you maximum positive camber, you can't surpass this so any argument that fine turning is irrelevant because you can't hit the goal regardless.
You either don't know what you're talking about which I find not to be the case. Or you're purposely distorting what I have said and spewing your insidious crap out on purpose to get a response.
I'm taking option two, if I met you in person I think you might need a gig on that nip and tuck show because your nose would be different.
Some people might say you're a narcissist, but they're wrong.
You sir are a pathetic sociopath.
And I know how to deal with people like you, that is to expose them.
