- Apr 15, 2006
- 22,640
- 20,538
- 113
- Location
- Sth Auck, NZ
- HSV VS Senator, VX Calais II L67
i think he means unbalanced as in the v6 is a pos compared to the inline 6 in terms of efficiency
So how does that work when you compare a V8 Vs Inline 8 cylinder engine?
Yeah, that's what I mean. It would have some sort of effect on the torque production would it not?
Torque is rather simple. Force over distance. Unless you go to offset bores and/or offset rod/piston combinations there is no real difference. By your reasoning If the inline engine is king and the V engine is POS that what about the boxer engine configuration?
The I6 engine works because of the number of cylinders and the firing pattern which creates a smooth engine. By the same virtue a I4 is crap for harmonics and it's common for these to have balance shafts to smooth out the engine harmonics. Doesn't effect engine efficiency however.
To me it looks like they have found the limit of something in the engine combo and hence the reason it doesn't keep creating any more power even though it still has plenty of revs.
At the end of the day, they are still running the factory heads and full intake so in terms of power produced it's bloody awesome. I'd be interested to see what it could do with a custom intake as I suspect this may be where the limitation is (compare runner length and cross-section Vs the I6 shown above).
