vombil
I put HPR30 in it and it knocked immediately and had zero pressure. thicker oil should have brought pressure up if bearings was the issue right?If that was the case blocked ports on the crank would increase the pressure, lack of pressure is because the bearings and journals have to much clearance that means engine wear. I say the only way to know whats going on is a engine pull down.
