7E8 Engine, 7EA
birch
Toowoomba
2008 VE Commodore Sv6 3.6 Series 1
My 2008 VE commodore Sv6 Automatic, Has started to display ABS fault, Stability, Everytime I turn my car on. I connected a code reader to it. And i find 7E8 Engine and belong 7EA, I click on either one to find the code and they don’t come up. And no I haven’t deleted any codes. Can someone help. I have been looking in the Haynes workshop manual only because I can’t find a gregory’s Workshop manual.
VTS5
TechJunkie
Sth.East\Melb
VE OMEGA 3.6L Dual Fuel
$7E8 and $7EA are menu headings ,
We have a Tech2 at work,some time ago customers car showed stuck thermostat (not saying for yours)so better find a Tech2 (Will give you a proper reading/result ).
Dread
39
Auckland
Vz
Mine shows that if I pull the traction control fuse out maybe the fuse blew sorry just a thought
lout
60
Langwarrin Victoria
$7e8 means ecu has a code
then scan ecu for that code
$7ea means tcm has a code
then scan tcm for that code
losh1971
North Tas
VE Series I SS Ute
It's could a battery on its way out. I'd have it load tested just to rule it out.
losh1971
North Tas
VE Series I SS Ute
Why did this thread come up on my new list? Last reply before mine was over six months ago, weird?
Fu Manchu
WA.
The same thread topic is also running about the same code where it’s just not getting through that all the code readers are junk.
losh1971
North Tas
VE Series I SS Ute
Ohh yeah, that thread.....:rolleyes:
